Cannot click rows inside drop down list
Home › Forums › Ask Expert › Cannot click rows inside drop down list
- This topic has 3 replies, 2 voices, and was last updated 7 years ago by Valentin ZAP.
May 2, 2017 at 12:13 pm #31068Leidz BigayParticipant
Hi Everyone,
I am encountering problems when running zaptest script that is clicking on a drop down list.
The drop down list disappears too fast after it is clicked by zaptest and I encountered these problems:
1. I am not able to record the rows inside the drop down list using the scanner
– while scanning, I press on ctrl key, click on the drop down to open the drop down but when I click on anywhere in the window the drop down list disappears before zaptest was able to record the drop down list rows
2. I am not able to click the rows inside the drop down list because the drop down list rows disappears too fast to do any action to it.
– when I run my script, zaptest is able to click the drop down list and the rows inside appears but only for a brief time, I am not able to click on any values inside the drop down because they already disappear before the next action is executed.Please let me know any tips for resolving these problems.
May 2, 2017 at 1:39 pm #31072Valentin ZAPKeymasterHi leidzb!
1. When you have serious difficulties with scanning something in your application you could create screenshot and then scan this view from a picture. But this way you should add this view to the exist application, otherwise you could get wrong “Application” parameters.
2. What do you mean? When ZAPTEST clicks on drop down list, it shows and disappears?! Could you provide more information and probably record your screen.
ZAPTEST TeamMay 4, 2017 at 7:03 am #31076Leidz BigayParticipantHi AndreySh,
I am successful using your first suggestion on the scanning of the Dropdown list.
However I am still not able to click on the items inside the drop down list.
I have tried the workarounds below, but none seemed to work on our app:Workaround 1
Hold CTRL key
Activate Drop down
Select Item from List
Release CTRL keyWorkaround 2
Hold CTRL key
Activate Drop down
Click with Move mouse down to select Item in drop down list
Release CTRL keyWorkaround 3
Hold CTRL key
Activate Drop down by double clicking
Select Row 1 on the drop down list
Release CTRL buttonWorkaround 4
Activate Drop Down
Click Row 1 in drop Down listWorkaround 5
Activate Drop Down
Move mouse down
Click Row 1 in drop DownWorkaround 6
Activate Drop Down by double clicking
Move mouse down
Click Row 1 in drop DownZaptest was able to Click the DropDown control, and the Drop down list items shows up but disappears very fast and Zaptest was not able to click the items inside before the drop down list disappeared.
I have attached the screen recording and zaptest file.
The screen recording starts on the comment: ‘Start of Video Recording’ in the zaptest script
Please let me know if you have any advice on how to resolve the issue.Thanks for the help.
Attachments:May 4, 2017 at 8:15 pm #31078Valentin ZAPKeymasterWe have inspected your script.
The biggest problem is:Object ‘Object(“ddUserMenu”)’ doesn’t have “Text” property. It means that OCR engine cannot be used and “Image Recognition” is used instead of. So this is very unstable, because selected area doesn’t contain graphic information.
Using you video file is difficult to understand where is the place when the menu is successfully activated. So we want to provide the following scenario:
' ZAP Solution
' Click on the Gear to activate the menu
' If this is not working, you could activate menu by using relative objects
' After this step Content Menu should be visible
Application("SecurEasy").View("Welcome").Object("btnGear").Click
' Use OCR Method To CLick on the menu item
' We have created siple object to click on "Log Viewer" item
Application("SecurEasy").View("GearMenu").Object("Log Viewer").Click
Let us know if this scenario works. ZAPTEST Script is attached.
ZAPTEST TeamAttachments: -
