Colored text does not scan
- This topic has 2 replies, 2 voices, and was last updated 8 years, 1 month ago by Barbara Jackson.
April 20, 2016 at 1:04 pm #30841Barbara JacksonParticipant
Hello ZAP,
In our web based applications we have a header which consists of tabs, in each tab there is a specific caption (Text):
When scanning the specific page using the Workbench we notice most of the captions of the tabs do not get scanned at all – Please help us to understand why this happens and if there is a solution to such issue.Thanks.
April 20, 2016 at 3:30 pm #30842Sasha ZAPModeratorHello BarbJack,
The colored text has different issues such as:
It may blend a bit with the background of its page’s color, or if it is a small and bold text it may be too dense to understand its meaning.
Basically there are 4 main options how to capture colored text:1. Open the ZAPTEST’s Workbench, assign new OCR object, set its true Text Color properties (By using the color picker and clicking with it on the actual text) and change other of its Properties (Such as the Text Color Tolerance) until the object will be found (To know if the object is being recognized properly by ZAPTEST you need to find it : move its created rectangular aside of the object, and click the Target icon next to the object’s name, if the object’s rectangular returns to the objet the object was found by ZAPTEST and it will be recognized by it).
2. Maximize the AUT (Application Under Test) page until all its colored objects will be visible without any problems, create a new View in the Workbench and scan the resized page, delete all unwanted objects and leave only the colored problematic ones.
3. Create a new Image based object, place its rectangle around the unrecognized colored text object, assign to it a Relative Object (Relative Object = In the same line of the object’s name there is a Hand shape icon, by clicking it you can choose from the captured screenshot at the right pane the nearby object you wish your specified object will be anchored to it, when you’ll want to execute a method upon the problematic object ZAPTEST will look first for the Relative Object and following its properties its anchored object can be found).
4. If the above 3 options did not help your ZAPTEST instance to locate the colored object, you can always contact ZAP and after doing a quick meeting and understand the issue ZAP R&D Department will create a fix to your issue and publish it in the next upcoming new ZAPTEST version.
SashaApril 20, 2016 at 3:41 pm #30843Barbara JacksonParticipantThank you Sasha for the detailed answer, we’ll try all your mentioned solutions and contact ZAP if non of them will work for us.
