how to use the scrollto and mousemove
Home › Forums › Ask Expert › how to use the scrollto and mousemove
- This topic has 1 reply, 2 voices, and was last updated 6 years, 9 months ago by Kirill Bulatnikov.
August 17, 2017 at 7:40 pm #31232chitanya kiranParticipant
i have some objects in my webpage at the scroll down of the toolbar.
I want to click and select those… let me know how to use the scrollto or mouse move methods.help me in the below code
site_url =”https://www.tycois.com/”
Application(“tycois-HS”).Launch Datatable.Value(“Browser”),site_url
Application(“tycois-HS”).View(“HS1”).Object(“ACCESS YOUR HEALTHCARE SECURIT”).Exist
Application(“tycois-HS”).View(“HS1”).Object(“Please Select Your M”).Exist
Application(“tycois-HS”).View(“HS1”).Object(“Image Object 36”).Click
Application(“tycois-HS”).View(“HS1”).Object(“Image Object 31”).ClickApplication(“tycois-HS”).View(“HS1”).Object(“Image Object 34”).ScrollTo
Application(“tycois-HS”).View(“HS1”).Object(“Image Object 34”).ClickApplication(“tycois-HS”).View(“HS1”).Object(“Image Object 33”).MouseMove
Application(“tycois-HS”).View(“HS1”).Object(“Image Object 33”).ClickApplication(“tycois-HS”).View(“HS1”).Object(“Image Object 30”).MouseMove
Application(“tycois-HS”).View(“HS1”).Object(“Image Object 30”).Click
Application(“tycois-HS”).View(“HS1”).Object(“Image Object 35”).MouseMove
Application(“tycois-HS”).View(“HS1”).Object(“Image Object 35”).ClickAugust 17, 2017 at 11:25 pm #31233Kirill BulatnikovParticipantHello ckiran!
Thank you for using ZAPTESTScrollTo method have to be used prior to the validation of the objects that not visible e.g. objects that not on the main screen.
In your example objects “ACCESS YOUR HEALTHCARE SECURIT”, “Please Select Your M”, “Image Object 36” and “Image Object 31” have to be visible on the main screen immediately after page load and next object (“Image Object 34”) seemed to be laid below the main screen.Also you don’t need to use MouseMove prior to Click method – in “click” mouse will automatically moves to an object. MouseMove really useful when you working with drop down lists activated by simple placing cursor onto it (but not need to be clicked).
Other then that your syntax looks correct.
ZAPTEST team -
