Login issue in ZAPTEST FREE EDITION
Home › Forums › Ask Expert › Login issue in ZAPTEST FREE EDITION
- This topic has 11 replies, 8 voices, and was last updated 3 weeks, 3 days ago by Maeve Maeve785.
February 3, 2017 at 12:22 pm #31015abhinav kumarParticipant
When we are try to login to ZAPTEST Free Edition while using our credentials, we are getting message as ‘Proxy Credentials Are Required’. Snapshot is attached.
Not sure what to enter here. Kindly help.
Regards Abhinav
Attachments:February 3, 2017 at 12:31 pm #31016Valentin ZAPKeymasterHi Abhinavmalviya1992!
It means, that you have configured a proxy on your computer. You should use your proxy credentials and also could save them in ZAPTEST configuration.
ZAPTEST uses system settings and you could change/set it using the “Internet Options” dialog:
- Open Internet Explorer
- Find and click “Internet Options” menu item
- Open “Connections” tab
- Click “LAN Settings” button where you will be able to update your proxy configuration
ZAPTEST TeamFebruary 3, 2017 at 12:42 pm #31017abhinav kumarParticipantDone.
But now not able to launch the application.
The tool is running as process in background but not visible,February 3, 2017 at 12:48 pm #31018Valentin ZAPKeymasterHave you seen the login dialog before? If yes – could you try remove this configuration file: “C:Users{YOUR_NAME}DocumentsZAPTESTPreferencesMainSettings.xml”
Does it help?
February 3, 2017 at 12:55 pm #31019abhinav kumarParticipantThanks a ton!!! It worked
January 5, 2024 at 6:35 pm #74684lorna lornaroa36ParticipantExperiencing login issues in ZAPTEST Free Edition. Hoping for a swift resolution to ensure uninterrupted testing. Your prompt attention to this matter is greatly appreciated for a seamless user experience.
January 5, 2024 at 6:45 pm #74685Sasha ZAPModeratorHello lorna lornaroa36,
First you need to register to ZAP in our portral, using this URL:
Then you can use your same regisatration credentials to login to ZAPTEST Free Edition.
ZAPTEST TeamJanuary 22, 2024 at 3:24 pm #75609Ava Gomes Ava123ParticipantIt seems that the ZAPTEST Free Edition is encountering issues with proxy credentials during login. To resolve this, you may need to enter the correct proxy credentials associated with your network. Consult your IT department or network administrator for the appropriate proxy information and ensure that it is correctly entered in the ZAPTEST Free Edition login settings.
February 2, 2024 at 11:05 am #75931Mercy MercyParticipant“I’m deeply grateful for the kindness and support of those around me. Your generosity brightens my days and reminds me of the beauty in this world. Thank you for being a beacon of light in my life[SIZE=1][URL=”https://youtubvanced.org/”%5D%5BCOLOR=”#000000″%5Dyoutube vanced[/COLOR][/url][/SIZE]
- This reply was modified 2 months, 3 weeks ago by Mercy Mercy.
March 15, 2024 at 4:43 pm #77790Shahid shahidParticipantHi, I just installed zap test and get the below error when trying to signup for the free version
You must be logged in to view attached files.March 22, 2024 at 5:46 pm #78246Sasha ZAPModeratorHello Shahid shahid,
I’m sorry for the late response, we were trying to reproduce your issue but could not get it:
Please try again to sign-up, it may be a temporary outage of server.
ZAPTEST TeamApril 2, 2024 at 7:01 pm #79236Maeve Maeve785ParticipantThe login issue in ZAPTEST FREE EDITION impedes user access, hindering exploration of its features. Prompt resolution is vital to ensure users can leverage the software’s capabilities effectively. Efficient troubleshooting and responsive support are crucial in addressing login challenges, enhancing user satisfaction and maximizing the platform’s utility.
