ZAPTEST Shared Repository
- This topic has 0 replies, 1 voice, and was last updated 7 years, 6 months ago by Sasha ZAP.
Home › Forums › ZAPTEST › Best Practices › ZAPTEST Shared Repository
ZAPTEST enables you to use one object repository (OR) upon multiple tests, this way you will not need to re-scan GUI + Add same objects + modify same objects over and over again in each related tests:
You simply decide which of your tests has the best and the most common OR, save the testing file in any directory, and by selecting the saved tests as the new Shared Repository (Test Settings -> Repository Location section – Note that this option is only available in the ZAPTEST Enterprise edition).
You can find information and learn how in the Forum -> How-To section:
